Action details: Clone issue Can not create issue in project/issue type 10145/10283
Adam Abela March 26, 2024
I tried creating this automation rule that will automatically clone an issue but it gave me an error.
The project that it is cloning to is a 'Business Project' and I have admin in both of the projects, but in the original Project the Project Access is Private. Could this be the issue?
Tugba Capaci
March 26, 2024
Hi @Adam Abela ,
Did you select the issue type for the cloned issue's project?
For example, in your current project, you have the issue type "question." However, in the project you want to clone, it might not have the same issue type. In this case, by selecting the appropriate issue type, the issue can be cloned successfully.
Tugba
actioner.com
Adam Abela April 2, 2024
Hi @Tugba Capaci
I did select the type and unfortunately the automation still gave an error.
Jerod Pennell
October 22, 2024
any update on this problem. having the same problem as well
John Funk
Hi Adam - Welcome to the Atlassian Community!
Yes, the permission is the problem. You must have access to Create Issues on the project that you are cloning to - or whoever is the Actor for the Automation Rule.
Hi @John Funk
Even though I created the Project that the issue is cloning to? Or do I also need permissions on the Project that the issue is being initially created?
John Funk
See if you can click the Create button and create an issue from scratch with the same information you doing by the clone.
Yes I can create an issue.
John Funk
And are you the Actor for the rule?
Yes.
John Funk
Wait a minute - the rule says to create in the WM project. Your example above is for the AF project. Try to create a Task in the WM project using the Create button.
Yes I can create an issue in the other project.
Sławomir Jałoszyński
@Adam Abela Did you found resolution? I have the same problem.
