×Hi All,
I'm using Jira Automation (in Cloud) and trying to assign the last comment the Assignee made into a custom field.
So far I can use {{issue.comments.last}} to assign the last comment into the customfield, however i need it to specifically be the assignee's last comment.
Thanks for your help
Hello @Robert Arcolas
Are you trying to do this retroactively, for issues where comments already exist?
As a go-forward solution you could implement a rule that is triggered each time a comment is added, check if the comment author matches the assignee, and then copy the comment to the custom field.
Hi Trudy,
Thanks for the suggestion! I didn't think to do it that way but I was able to get it working after reading your response.
Greatly appreciated!
@Robert Arcolas welcome! You might see the following thread: https://community.atlassian.com/t5/Jira-questions/Automation-how-to-copy-the-last-comment-of-an-issue-to-a-custom/qaq-p/1768691
Nicolas
