Automation for cloning tickets from one to another project and linking as it is.
madhu kiran
We have two projects one project we have template tickets feature->epic->story
second project when ever an initiative is created and a manually automation is triggered we need to copy all the tickets from template project and have them as children of Initiative.
initiative->feature->epic->story.
Hardik Babbar
September 25, 2025
Hi @madhu kiran !
Why not add links to the original "template project" features under the initiative in the second project?
I say this because if you clone the work items, you'll have duplicates of the same work which will not be synced with the original work items adding overhead and future sync issues (when field values, comments or status changes on the original work item)!
madhu kiran
Hi @Hardik Babbar ,
for every initiative we have to the have the tickets with some default details, so once it is cloned it will be changed according to the requirement.
Varsha Joshi
Hi @madhu kiran
Have you tried creating an automation rule? Could you share what have you created so far? It can be done; I have done that for one of our projects.
Trudy Claspill
Hello @madhu kiran
In addition to the questions asked by @Varsha Joshi :
  1. Are you working with Jira Cloud or Jira Data Center?
  2. If you are working with Jira Cloud, are you working with the Free, Standard, Premium, or Enterprise subscription.
  3. Have you modified the work item hierarchy to support a hierarchy of Initiative / Feature / Epic / Story?
madhu kiran
Hi @Trudy Claspill @Varsha Joshi ,
1. I am using Jira cloud premium.
2. yes i have updated the work item hierarchy.
I was able to clone issues and I was able to add initiative as parent to feature,
but i am facing issues when linking epics to features.
please let me know how i can do it.
