Automation on last comment
Giorgos Savva
Hi team,
I activated the following automation:
1. If comment ~ This can be closed
2. Then transition to DONE
What I need is to change the 'comment' to 'last comment'. The reason is that if the ticket reopens at a later stage, then the automation reads the comment again and closes it again.
Thank you in advance.
2 accepted
Ravi Sagar _Sparxsys_
December 9, 2020
Hi @Giorgos Savva
You can access the last comment using {{issue.comments.last}}
Ravi
Giorgos Savva
Thanks Ravi! It works also. Maybe it is a bit safer this way!
David Friedrich
December 9, 2020
Thanks for the infos. I created this rule with jira cloud automations and it worked. Reopened issue will not close on any other comment:
Giorgos Savva
Thank you David! It works :)
Like David Friedrich likes this
David Friedrich
December 9, 2020
Hi Giorgos,
happy to help, but i'd need more intel here ;-).
Are you using Server/Data Center or Cloud?
Is your question about the integrated service desk automations or project automations provided by automation for jira app?
Thanks!
Giorgos Savva
Hi David. I am sing Jira Cloud and project automations.
