Automation question - looping through lookup issues and setting fields outside the loop
Rees_ Ian
October 13, 2022
I have an automation rule that triggers when a version is released. When a version is released, I want to iterate through the stories, tasks and bugs in the release and find those that are children of Epics.  Then for those Epics, I want to update two custom fields.  I am nearly there - see attached.  But how do I then update two custom fields in the Epics (ITP-352 and ITP-353 in the example) with the values in the variables, varTotalStoryPoints and varCountTotalChildIssues.audit log for automation.PNG
Bill Sheboy
October 13, 2022
Hi @Rees_ Ian -- Welcome to the Atlassian Community!
Reading your use case and looking at your rule, it appears you only want to update the Epics' custom fields, summing information from their child issues.  Is that correct?
If so...you cannot nest branches in rules, and thus other approaches can be used.
Next question: are the epics assigned to the release?  The answer will determine how to proceed.
Yes, the epics are in the release also
In this case, just branch on the epics instead in the rule...
  • trigger: version released
  • branch: on JQL to any issueType = Epic AND fixVersion = "{{version.name}}"
    • action: lookup issues for the child issues of the epic which are in the release
    • action: edit issue to change the epic for the custom fields, using the lookup values, such as {{lookupIssues.Story points.sum|0}} and {{lookupIssues.size|0}}
No, the epics are not in the release
Similar to above, except the first step is to find the epics so you have them to walk for the branch...
  • action: lookup issues on JQL to find all issues in the release which are children of epics
  • branch: on JQL to the epics with key IN ( {{lookupIssues.parent.key.distinct.split(",")}} ) AND issueType = Epic
Rees_ Ian
October 14, 2022
Thanks Bill -
It appears you only want to update the Epics' custom fields, summing information from their child issues.  Is that correct? - Yes that is correcty
The Epics are not in the Release. The epic may contain multiple issues that are released in different releases.  I will try the branch suggestion. Thanks for your help
Like Bill Sheboy likes this
Rees_ Ian
October 17, 2022
Thanks @Bill Sheboy
I am trying to follow the logic and have tried this but am hitting a few problems. May I ask few questions
1. Re - "
  • action: lookup issues on JQL to find all issues in the release which are children of epics"
    I have done this in my rule (see attached).  Why is it necessary to do the lookup again as does it not produce the same results that I am iterating through with the trigger
2. "branch: on JQL to the epics with key IN ( {{lookupIssues.parent.key.distinct,split(",")}} ) AND issueType = Epic"
When I try to enter Branch as the next component in my automation, Branch is not an option - any idea why that would be ?
3. What is lookupIssues.parent.key.distinct,split(",")}} doing ?
Thanks Ian
Bill Sheboy
October 17, 2022
Your #1 item)
  • For the "epics are not in the release" approach, the first lookup was to find the epic's keys.  Then inside the branch, and as each epic is walked, a second lookup was used to gather the stats for the relevant issues.
Your #2 item)
  • This could be because you are already in a branch, and so the editor prevents that.  Please post an image of your current rule, highlighting where you are trying to insert the branch.
Your #3 item)
  • What does  lookupIssues.parent.key.distinct.split(",")}} do...
    • That lookup was on all issues in the release which have an epic parent
    • And so we only care about the parent's keys
    • And we do not want them repeated (e.g. multiple issues in an epic), so we select them with distinct (I just noticed my typo of a comma rather than a period, which I fixed)
    • With that resulting list, we then want to use split() to create individual parent (epic) keys to walk in the advanced branch
Like Rees_ Ian likes this
Rees_ Ian
October 18, 2022
Apologies I forgot to add the image.  I have highlighted in yellow where I am trying to branch and you are right I am trying to branch in a branch.automation prob.PNG
Rees_ Ian
October 18, 2022
Thanks @Bill Sheboy I can see now why I had a branch in a branch and now I have removed the outer "For JQL" it makes sense and runs as far as
which fails with NO ISSUE: "(key IN ( [ITP-nnn], [ITP-nnn] ) AND issueType = Epic) AND (project in (nnnnn))" - Error in JQL Query: Expecting either a value, list or function but got '['. You must surround '[' in quotation marks to use it as a value. (line 1, character 11)
it looks as though somehow I need to parse out the square brackets to get valid JQL
Rees_ Ian
October 18, 2022
Rees_ Ian
October 18, 2022
Thanks for your help @Bill Sheboy I think I'm through the hard bit - I parsed the JQL string with a couple of temporary variables and the last bit of assining the variables now should be straightforward - much appreciated your helpCapture.PNG
Rees_ Ian
October 18, 2022
What you can't see from above is the parse as follows
varStrA = {{lookupIssues.parent.key.split(",")}}
varStrB = {{varStrA.remove("[")}}
varStrC={{varStrB.remove("]")}}
Couldn't see a way to reuse variables without creating a new one :( but works
Bill Sheboy
October 18, 2022
Awesome, and I am glad you figured it out!
You can also chain those things together in one step:
{{lookupIssues.parent.key.split(",").remove("[").remove("]")}}
Rees_ Ian
October 19, 2022
Interestingly the chain didn't work
varChainedStr = [], [], [], []
versus
varUnchainedStrC = ITP-352, ITP-352, ITP-352, ITP-353
Rees_ Ian
October 19, 2022
However
varChainedStr = {{lookupIssues.parent.key.remove("[").remove("]")}}
varChainedStr  = ITP-352, ITP-352, ITP-352, ITP-353
So don't need the split :)
Thanks for all of you help @Bill Sheboy
Bill Sheboy
October 19, 2022
Yup...some of the "list" functions return a list (an object) and some appear to return a text collection (a delimited list of text).
It is often good to write values to the audit log first to confirm what is happening, versus what the documentation says  :^)
