I have added three numeric custom fields to an epic:
I would like to create automation rules to calculate the total number of issues for each field based on the status category of the derived/child issues. One trigger would be whenever an issue is added/removed to the epic and the other one, when the status of one of the child issues changes.
I played around a bit, but couldn't get it to work. Any ideas?
In Jira Cloud we have recently introduced a "Lookup issues" action that allows you to lookup issues via JQL and then reference them later in the rule as a smart-value.
With this you could have a rule:
Does that work for you?
Nick Menere [Atlassian]
Unfortunately this is a Cloud only feature with no plan to migrate to the Server.
