I wish to create a custom field for my issues that automatically create a series of web links. I don't want to use the URL field as it displays the whole url as well as needing more than 1. I want the link to be displayed like - this link is google .
Ive tried a paragraph field that supports rich text but do not know how to write rich text with JSON. How would I go about doing this?
Hi @RR,
Paragraph fields are using Wiki Renderer notation, so in order to create the link with an alias you would do it like this:
[Atlassian|https://www.atlassian.com]
That would give you a link like this Atlassian. You would also have to change the renderer used in the project. Go to Project setting > Fields and edit the field configuration. Look for your field and click on Renderer and select Wiki Style renderer.
