Edit issue custom field with smart value from webResponse.body
Grzegorz Ostrowski
In my automation rule I use send web request component. It returns me for example this json in {{webResponse.body}}:
{"zadanieNumer":"ZGL/2022/02/11","zadanieGuid":"dcc40184-e41c-4d70-97a9-053f6039b4cc"}
In next step i use Edit issue component to set value to custom field.
When I set field with value: {{webResponse.body.zadanieGuid}} i get empty value.
The same with {{webResponse.body.zadanieNumer}}. It should be possible to get value this way. Can somebody write mi what I am doing wrong?
I added screen with my Edit Issue component.
Mark Davidson
February 9, 2022
Hi @Grzegorz Ostrowski ,
I went ahead and tested your smart value and it's valid so there's no issues there.
Could you confirm that you have the setting in the image below set?
Json Tester --> https://jsonpath.com/
Grzegorz Ostrowski
@Mark Davidson Yes I have it checked
I have if/else compound after web request compound to handle response. I get correct response. And correct json in {{webResponse.body}}.
Mark Davidson
February 10, 2022
If possible could you please share a screenshot of your entire automation rule, hard to tell that one of the many factors that could be effecting this aren't present.
Grzegorz Ostrowski
@Mark Davidson This is schemat of my automation rule:
Grzegorz Ostrowski
@Mark Davidson  I have managed using this code in Edit Issue component to get values from JSON {"zadanieNumer":"ZGL/2022/02/11","zadanieGuid":"dcc40184-e41c-4d70-97a9-053f6039b4cc"}.
But it should be as simple as {{webResponse.body.zadanieGuid}}. Why it dont work in my case. Is this some kind of bug?
Sam Harding
February 13, 2022
From your solution you've posted above, it seems like the webhook body is being read in as a string, and not the dictionary/map structure. Is it possible to check whether the webhook sender is encapsulating the data inside a string when it sends the webhook?
Like Bill Sheboy likes this
