Error running basic automation on next-gen project
Adam Foot December 20, 2020
The goal is to create an automation that when run creates a Task with Subtasks.
To try & achieve this, I've created a very simple automation task configured as follows:
Create a new issue in:
Project: Test
Issue type: Task
Summary: task test
Project: Test
Issue type: Subtask
Parent Issue: Current issue
Summary: subtask test
However when run, it shows the below output including an error at the subtask step:
Action details:
Create issue
Issues created successfully
TEST-32
Create issue
Error creating issue
Issue type is a sub-task but parent issue key or id not specified. (issuetype)
Please advise what the problem is here?
Ash Pitt
Hey @Adam Foot
I believe you would want to select the "Create sub tasks" action.
Basically
  • When: Issue created
  • Condition: Issue type equals task
  • Action: Then create x sub tasks
That should do it :)
Thanks @Ash Pitt for the prompt reply.
I did see that option, but the problem I encountered is that it doesn't let you set additional properties on the create sub-tasks action page e.g. assignee.
When I click on add fields it takes me back to the standard create issue page where I had originally configured the subtasks & therefore have the errors.
Here is a snip of what I'm trying to achieve - it begins off a scheduled time trigger:
Based on the above, would there still need to be conditions added?
Ash Pitt
Hello again @Adam Foot
I only added in the condition to specific adding the task type only, so it's not required really, that's just how I'd filter it down to "task only".
To assign a user I just used the "add fields" part of the sub-task automation and was able to automate the assignee to the reporter. There are plenty of other options though!
So it looks like you're on the right path, just play around with the "Add fields" options.
IMO to test the function out first (if you haven't already) do the automation triggers based on when the issue is created, then when happy, flick to scheduling.
Cheers
Ash
Hi @Ash Pitt I'm unfortunately still getting the error when running the very basic automation shown in my previous post. The error details are below:
Capture3.PNGAny ideas?
Ash Pitt
Ok so with scheduling I think you will need to use the branch rule function.
In my example below I wanted to have a task created with sub tasks every day, so I set it up similar to what you did, however used the branching rule for the most recently created issue (which is that task) to create 2 sub tasks.
I think that will sort you out :)
Like # people like this
Adam Foot December 21, 2020
Thanks @Ash Pitt that worked!
Lastly, even though the Assignee is specified in the rules for both the Task & Subtask, it's still making "Automation for Jira" the Assignee.
Any ideas on how to solve that one?
Ash Pitt
Yep I have ideas :)
Within the task/sub task settings you can choose the fields to set, so in that case I chose the assignee and the reporter (though it should work for whatever fields you have set up the require an assignee) - then you just specify who you want it to be assigned to.
Works a treat for me.
Adam Foot December 22, 2020
Hi @Ash Pitt that's a different result from what I get.
I have it set the same, for the assignee to be x user during the create a new Task & Subtask. However it ends up being "Automation for Jira" as shown below:
I did notice that the Actor is Automation for Jira under Rule Details, but I assumed this is still achievable without changing that:
actor.PNGWhat do you think?
Ash Pitt
Merry Christmas @Adam Foot
Changing the actor I think works, however there is caution to be taken with that as well.
However it does work :) note the NGD-50 is the one i set up as me being the actor.
actor2.PNGHopefully that (now) has helped you get cracking with automation!
Cheers and a happy new year
Ash
Adam Foot December 28, 2020
Hi @Ash Pitt , even though the assignee is set to be user_b, it's making the assignee for both the tasks & subtasks whoever the "actor" is in the automation e.g. if I change the actor to myself, it makes me the assignee for all tasks & subtasks in the automation. If I change the actor to Automation for Jira, then that becomes the assignee.
This is despite the assignee being specifically set in each rule of the automation e.g. create subtask & set the assignee to be user_b.
Any ideas?
Bill Sheboy
December 29, 2020
Hi @Adam Foot
As you have been improving your rule, please consider posting a new image of the current rule.  That may help uncover the issue with the edit and the assignment.
Thanks, and best regards,
Adam Foot December 29, 2020
As suggested, here are some screenshots of the automation:
Results in the assignee being Automation for Jira:
Bill Sheboy
December 30, 2020
Yup, that looks like a defect.  When you look at the individual task's history does it show as only assigned once to the automation user?
I looked in the public backlogs and didn't see a defect for this, so if you are on a paid license I suggest submitting a defect for this, and then post back here what you learn from the support team:
https://support.atlassian.com/contact/#/
Like Ash Pitt likes this
Adam Foot January 3, 2021
Thanks Bill, the assignee was just caused by a Workflow issue.
