How can I set an automation slack for jira when a due date is approaching?
Siti Nur Atikah
For example, an intern will end their internship on 12/11/2021. How can I set a reminder that will be send to a channel in slack 2 weeks before the internship ended.
For Ng Sze Jin, the due date for internship is on 31st December 2021. So, I want a channel in slack to give reminder that her internship will ended in 2 weeks before the due date. I try to schedule the date and set it to every day. I am not sure if this is possible.
I need someone help me. Thank you.
Ravi Sagar _Sparxsys_
November 11, 2021
Hi @Siti Nur Atikah
You need add in your JQL sub query to filter issues based on due date. Something like this.
due >= -1w AND due <= 2w order by created DESC
I hope it helps.
Ravi
Siti Nur Atikah
can I know what do you mean by DESC?
November 11, 2021
Well it is just to get the results in descending order based on creation date. You don't have to use it.
This query should also work fine.
Ravi
Like Siti Nur Atikah likes this
Siti Nur Atikah
Is it the Cron expression refer for notification time?
Siti Nur Atikah
Hi. I have tried your solution and it works for a particular person just like I wanted. Thank you. But, there is one more thing that I am not sure of. How can I change the schedule to 2 weeks before the due date. In this picture, I set the schedule every 5 minutes. But in my case, I would like to give reminder 2 weeks before due date.
