How to run a script in jira automation?
Jamshaid
February 26, 2024
I need to run a script to perform some changes on the values of a custom fields by splitting the value based on a specific string. How do I run such script in jira automation?
2 accepted
3 votes
Darryl Lee
Hi @Jamshaid --
So Jira Automation doesn't support running scripts (Bash, Python), but it might be able to do what you want using built-in functionality.
If this is a one-time thing you need to run, you could use a Manual Trigger.
And then to update a custom field value, you would use the Edit Issue action.
Within the text field Smart Value functions, there is a split, which might help you accomplish what you are trying to do.
If you need more assistance, please provide the specifics, and we can help.
Jamshaid
February 28, 2024
@Darryl Lee thanks for responding. I need to split this value
52-CT83 that is in custom field PROJ to 56 and CT83 and set 56 to a custom field. How do I do this using automation?
Ramchandh April 28, 2025
@Darryl Lee
1. I want to trigger an automations script(Bash/python) from jira.
2. It should trigger an job in bamboo.
3. The job in bamboo expects arguments that has to be passed from jira to bamboo job.
4. once the job is successful, it should auto resolve the jira,
     If it fails it should update the jira with the error message.
Darryl Lee
Ohey @Ramchandh , so when I wrote this:
I totally forgot about Web Requests! Also, I've only investigated Automation for Jira Cloud.
For #1, I still don't think it's possible to do that unless you're running Flask or some other kind of server that is listening for web requests.
And so... for #2, a Bamboo job can be triggered by Jira Automation. Here's a HOWTO from Atlassian:
Re #3, hrm, it looks like the only arguments you can pass are a PLAN-KEY and whether to skip branches or not.
As for #4, if your Bamboo is linked to your Jira then yes, it seems like you ought to be able to use the Build successful or Build failed triggers to accomplish what you want.
Jamshaid
February 28, 2024
Thanks to the hint by @Darryl Lee , I have got it working with the following flow
Darryl Lee
Glad to see you got it working! Sorry I misunderstood what you meant by "running a script". I'd appreciate if you could accept my answer below, since it did lead you to the split() command that you were looking for.
S Sajeed Ahamad September 5, 2024
Hi, I am a JIRA Developer and part-time Freelancer. I provide support for all types of Cloud and Data Center scripting solutions, including Groovy and SIL. I specialize in Listeners, Behaviors, Conditions, Validators, and Custom Post Functions. If you need assistance, feel free to contact me on WhatsApp at +17866876777 or via email at freelancerjira@gmail.com.
you can reach out to me i will solve your problem
