Dear Atlassian Automation Community,
I have defined my Jira issues hierarchy to Initiative>Epic>Task
I have defined a Related Product field on each of the issue types and would like to set an automation that will cascade the Related Product field value set in the Initiative level to all it's Children (i.e. branch for children and then branch once again for their children)
Can anyone assist in suggesting an automation approach to achieve this goal šš¼
Hello @Shmuel_ Dave
I can suggest to use another way :
Hope this can work on your instance
Hi @Shmuel_ Dave -- Welcome to the Atlassian Community!
You may need additional automation rules if you want to handle other possible scenarios / edge cases. For example:
Yep...
That's correct šš¼
Here is what i have added so far -
Added one for when issues are created under an existing issue -
Hi Dave - Welcome to the Atlassian Community!
I usually do that with two different rules. So create a rule based on a Field Value Changed rule. Leave it for all types of changes.
Then add a Condition for Issue type = Initiative
Then add a Branch for Children
Then add an action for Edit Issue and select the same field.
In the blank below the field name put: {{triggerIssue.Related Product}}
This will update the Epic field with the value from the Initiative.
Then copy that rule and give it a new name.
Change the new copied one to change the Condition from Initiative to Epic. Be sure to check the box on the Rule Details to allow it to fire the trigger when another rule fires.
Then you are ready to test it out. The first will fire and update the value in the Epics, which will cause the second rule to fire, which will update all of the Epics' children.
