Hello!
I've got an automation from Jira.
The intention is that every time a deployment happens, the list of issues from the deployment get put into a slack message, and then sent to a slack channel.
What is currently happening is: we get N messages, with N issues in each message. If we've released 10 items in the release, we get 10 messages with all 10 issues listed in each.
What am I missing?
Apologies that you've run into this, we really need to rename these actions as it is a bit deceptive. They should be called issue deployed successfully. The trigger runs once for each issue in a deployment.
This is why you are seeing this behaviour.
Simeon.
Hi @Simmo
Thanks for the information! From that trigger's smart values, it is possible to detect for which issue the rule is running? https://support.atlassian.com/cloud-automation/docs/jira-smart-values-development/
If so, @Quinn Moffat could:
Hey @Bill Sheboy,
I like it, thats some fancy thinking! I think so. {{issue}} should still work I believe so you can get the issue key that way!
@Bill Sheboy I've given this a go:
I couldn't get the key within the conditional for whatever reason, so I've used the description field.
Nice! I am wondering why {{issue.key}} was not available for the comparison.
Got any ideas, @Simmo ?
@Bill Sheboy not in this case I'm afraid. It should be available or the rule would have errored. Would probably have to work backwards and start by adding a log component for {{issue}} and see what that gives, then go from there.
Hi @Quinn Moffat -- Welcome to the Atlassian Community!
Your rule seems to match the same use case shown here for this trigger: https://community.atlassian.com/t5/Automation-articles/New-Build-and-Deploy-triggers-for-Jira-automation/ba-p/1442789
When you look at the audit log, does it show the rule being triggered multiple times for the same deploy?
Hey Bill! Correct. One deploy = N iterations,
where N is number of issues deployed
