Not able to use String function with Smart Value in lookup object
Sarika Dalal
Hi Team,
I got one requirement from customer for insight object, they have one Object Schema In that they are creating object they want once any object got created field AssetID value should be automatically increment by one in the last Object AssetID
Let's take one example here
Object Key    AssetID
LAB-123        ABC001
LAB-124        ABC002
LAB-125        ABC003
So the field AssetID value should be automatically added, so I am using Automation in JSM
Here is the details about the configuration :
When: Object Created
Then :  Lookup objects
insight query language is
objectType = TEST ORDER BY AssetIDD DESC
here AssetIDD is text field
Then : edit Object
Select field : AssetIDD
Value : {{lookupObjects.get(1).temp_Asset_ID.charAt(2)}}
ERROR:
Edit Insight field attributes
Error updating Object(s)
Objects were skipped
LAB-6858 (temp_Asset_ID = '')
So this is the configuration I have  added but I can see all the text function is not working here and getting always empty value and in Automation audit log I can see error, I can achieve same requirement If I am using only number field but with text field no smart value function is working
following this document : smart-values-text-fields
Any suggestion why my text function are not working ?
Sarika Dalal
Ignacio Pulgar
January 13, 2022
Bill Sheboy
October 28, 2021
Hi @Sarika Dalal
First thing, I do not have Jira Service Desk, so I will try to help based on what I see in your automation rule.
  • Is temp_Asset_ID a defined field in that lookup, as it may not be present if it is returning as empty?
  • For {{lookupObjects.get(1)... I believe this is trying to return the second item in the list, as these are 0-base indexed.  Is that what you want?  Otherwise if you want the first one, perhaps try: {{lookupObjects.first...
  • Your AssetID values are of the format ABC001, and you are trying to access at charAt(2).  According to the documentation, this one is 1-base indexed, so this may not be what you want.  Consider writing the values to the audit log to confirm what is happening.
  • And, as your AssetID values are alphanumeric, if you are trying to increment with a rule, wouldn't you need to split that value into the alpha and numeric parts, increment, and then concatenate the result?
Sarika Dalal
Thank you for the response @Bill Sheboy .
let me add few more points here :-
when I am trying {{lookupObjects.get(1).temp_Asset_ID}} its giving me value of the field after that I am using function {{lookupObjects.get(1).temp_Asset_ID.charAt(2)}} that is not working. with charAt function I am just testing String functions.
Issue is all string functions is not working here and every time I am getting null response.
Your thought is correct about point 4 I am going to split number and text field value only and then I will do increment in number.
Sarika Dalal
Bill Sheboy
November 1, 2021
You are using Cloud, correct?  If so, perhaps do this in two steps to force the type conversion to string:
  • create a variable and set the value to the temp_Asset_ID
  • then perform the charAt() on the variable
I recall needing to do this for other fields which are dynamically generated before I could use them in expressions.
