Rule will not run when a comment is updated
hero July 2, 2023
when I choose a trigger issue commented,which describe Rule is run when a comment is added to an issue,will not run when a comment is updated!screenshot-20230703-133306.png
3 votes
Sayed Bares [ServiceRocket]
@hero welcome to the community!
if you want to trigger the automation when a comment is updated then use
Issue comment edited trigger instead. Issue Commented will only run when a comment is added to your issue.
hero July 2, 2023
thank you for your response,but I could not found Issue comment edited trigger anywhere.
Like John Funk likes this
@hero it looks like you are using Jira Server/DC. You can use 'Multiple issue events' rule with issue comment edited event instead.
hero July 2, 2023
I found Issue Comment Edited in Multiple issue events,thank you very much!
Like # people like this
You are most welcome @hero !
John Funk
Hi hero - Welcome to the Atlassian Community!
Is this rule being triggered by another rule? If so, click the box for Allow rule trigger on the Rule Details page.
If that doesn't apply, can you share when the Audit Log for when the rule is run?
hero July 2, 2023
there is no audit log for my operatation,because Issue comment Trigger will not run when a comment is edit.
