I've been experimenting with an ask from Epic owners to get a consolidated report emailed at EOD of all Done issues that are linked to the Epic.
I'm stuck on the linked issues part of the automation. Any links you guys know about that can help? Or, does this ring a bell of something that you've accomplished for your own projects?
Thanks!
Is it really an issue link (are thos issues link with a special link type to the epic like for example „relates to“) or are thos tasks/issues you are trying to fetch tasks within the epic (child issues)?
In case of child issues you could fetch them with a JQL
„Epic Link“ = <issueKey of yourEpic>
Best
Stefan
Stefan, I'm not finding success. Can you please break down this automation piece so that I can understand where I am going wrong?
Thank you.
Could you please show a screenshot of your rule, how far you‘ve come so far and where exactly you got stuck? This might help to analyze the problem and get a better understanding of what you‘re trying to achieve.
Furthermore could also further specify your requirement and what exactly you would expect from the result.
Best
Stefan
Stefan,
Here is the rule as I have it now. I think I may have got the linked issues worked out with 'Parent exists'. I still have no idea how to email the Parent assignee though.
Stefan,
Well, it looks like I figured out how to email the epic assignee with {{issue.parent.assignee.emailAddress}} but the email did not show the issue that should have been reported with the conditions.
I'm getting there!! :)
