#lookupIssues not returning any values
Kunal Kumar April 2, 2023
@Bill Sheboy
Use case : For each reporter , all the issues he has created without mandatory tags a consolidated email needs to be sent with jira links of all the issues.
Using issue.toUrl simply sends one email per issue ( ex 5 emails for 5 issues ) & #lookupIssues is sending emails with blank body. Below are the screenshots :
Bill Sheboy
April 3, 2023
Hi @Kunal Kumar
To use the {{lookupIssues}} smart value, you need to first call the Lookup Issues action.  Please try this change to your rule:
  • trigger: scheduled with no JQL
  • action: lookup issues with the JQL you previously had in the trigger
  • action: send your email
Kunal Kumar April 4, 2023
Get it , but I am on JIRA server and lookup issue action is not available for me to use. Is there any other way I can achieve this use case ?
Bill Sheboy
April 4, 2023
Thanks for clarifying, as your post indicated you were using Cloud but you are actually using Server/Data Center.
The Server/Data Center version has an option for bulk-issue processing.  This is a setting you select either with the Scheduled Trigger with JQL or with a Branch.  After enabling the setting, you would use the {{issues}} rather than the {{lookupIssues}} smart value.  https://confluence.atlassian.com/automation/run-a-rule-against-issues-in-bulk-993924653.html
You can use your original rule with JQL in the scheduled trigger, enable bulk processing, and replace {{lookupIssues}} references to {{issues}}  Please note that is plural {{issues}} for bulk-issue handling.
Like Nikolai likes this
Kunal Kumar April 5, 2023
Thank you so much @Bill Sheboy Worked like a charm
Like Bill Sheboy likes this
