Use case : For each reporter , all the issues he has created without mandatory tags a consolidated email needs to be sent with jira links of all the issues.
Using issue.toUrl simply sends one email per issue ( ex 5 emails for 5 issues ) & #lookupIssues is sending emails with blank body. Below are the screenshots :
Hi @Kunal Kumar
To use the {{lookupIssues}} smart value, you need to first call the Lookup Issues action. Please try this change to your rule:
Get it , but I am on JIRA server and lookup issue action is not available for me to use. Is there any other way I can achieve this use case ?
Thanks for clarifying, as your post indicated you were using Cloud but you are actually using Server/Data Center.
The Server/Data Center version has an option for bulk-issue processing. This is a setting you select either with the Scheduled Trigger with JQL or with a Branch. After enabling the setting, you would use the {{issues}} rather than the {{lookupIssues}} smart value. https://confluence.atlassian.com/automation/run-a-rule-against-issues-in-bulk-993924653.html
You can use your original rule with JQL in the scheduled trigger, enable bulk processing, and replace {{lookupIssues}} references to {{issues}} Please note that is plural {{issues}} for bulk-issue handling.
