I am trying to get the total number of tickets for each status in Jira. but the output keeps giving me 1 or 0. So I write a jql to get all the jira ticket types. example below
Trigger is schedule
then action is lookup issues using this jql: project = "Fake" AND type IN ("Fake1", "fake1 Subtask") AND status IN ("New", "In progress", "Follow up", "Update", "second Followup") ORDER BY created DESC
and then send email with this
- Total tickets in "In Progress": {{lookupIssues.size for status "In Progress"}}
- Total tickets in "New": {{lookupIssues.size for status "New"}}
- Total tickets in "Follow up": {{lookupIssues.size for status "Follow up"}} etc
Output is below
- Total tickets in "In Progress": 0
- Total tickets in "New": 0
- Total tickets in "Follow up": 0
- Total tickets in "Update"": 0
- Total tickets in "Second Follow up": 0
Please can you assist this. the expected output should look like below
- Total tickets in "In Progress": 20
- Total tickets in "New": 6
- Total tickets in "Follow up": 5
- Total tickets in "Update"":30
- Total tickets in "Second Follow up": 55
Hello @phebean Atoyebi
Are these literally the smart values you are using in your email?
If so, those are not valid smart values. Only {{lookupIssues.size}} is a valid smart value. You can't add for status "Follow up" to get a subset of the Lookup Issues results.
There are a few ways you could handle this.
One is to use a Lookup Issues action for each status, and then save each result to a separate variable. Then use the variables in your email
Not that this affects your answer, but isn't there a limit of 100 issues returned when you do a lookupissues? Or am I remembering another limit for something else?
Good point @Malka Jackson [Isos Technology]
Yes, there is a limit of 100 issues being returned by the Lookup Issues action. That is documented here:
https://support.atlassian.com/cloud-automation/docs/automation-service-limits/
Given the numbers shown in the example by @phebean Atoyebi the total number of issues expected when combining all statuses into one Lookup exceeds the 100 issue limit. So based on that, separate Lookup Issues actions will be needed to get subsets of the issues.
@Malka Jackson [Isos Technology] I will figure out other options other than lookup issues that exceed 100
You may want to take advantage of the free, on-demand training available from Atlassian at https://university.atlassian.com . Among the many courses they offer are some courses specifically about Automation. You can find them by searching for jira automation
Hi @phebean Atoyebi -- Welcome to the Atlassian Community!
In addition to the 100 issue limit noted by other suggestions, another way to get the counts is using smart value, list filtering and a math expression:
The benefit of this approach is there is only one call to Lookup Issues, making the rule faster and less likely to have maintenance errors if the JQL changes.
For example, if there is one Lookup to return all of the issues, the counts would be:
- Total tickets in "In Progress": {{#=}}0{{#lookupIssues}}{{#if(equals(status.name, "In Progress"))}}+1{{/}}{{/}}{{/}}
- Total tickets in "New": {{#=}}0{{#lookupIssues}}{{#if(equals(status.name, "New"))}}+1{{/}}{{/}}{{/}}
That works by:
Thank you for providing that, @Bill Sheboy .
I thought there was probably a method like that, but I haven't spent much time working with the logic options.
