Send web request, handle response code not equal to 200
johanzetterlund
January 18, 2021
I am trying to write an Jira Project Automation that sends a webrequest.
If I get a response code that is NOT 200 I would like to send another webrequest to another url.
I am trying to use:
If: matches
But the problem is that Jira Automation stops the execution if the webhook response isn't 200 so it is not event trying to send to my second webserver.
This is the Audit log:
Status: SOME ERRORS
Action details:
Send web request
Error response HTTP body:Error publishing webhook. Response HTTP status:400
Is it possible to read the response.status and send a new webrequest if it's not 200?
Darryl Lee
I'm thinking it's not possible. I had a web request that had a possibility of failing, and I tried to "trap" for unsuccessful requests by checking {{webhookResponse.status}}. It never worked.
Alas, upon closer inspection, you only that smart value that if it's successful:
On successful webhook execution, you would be able access webhook response data using the following smart values:
I think we'll need to ask for a Feature Request. :-}
johanzetterlund
January 18, 2021
Thanks for the reply!
Hmm ok, I'll have to work around this in another way, then.
Like Darryl Lee likes this
Kerrick Cavanaugh
June 13, 2024
Is there an update on this? I am trying to do the same.
Like abderrahmane.zaibak likes this
Kevin Bianchi
June 28, 2022
For information, since version 8.0 from Jira Automation.
The rule now continue even if the response is in error.
This will allow to test this value.
https://confluence.atlassian.com/automation/send-web-request-action-now-provides-response-data-993924775.htm
What is strange is that ticket https://jira.atlassian.com/browse/JIRAAUTOSERVER-180  is still open.
