I am setting up a public widget for clients to contact us for support however we will require them to put in their email address in a field and we will use the domain of that email to trigger an alert in Slack and assign to an agent who specifically deals with this client.
I couldn't find a trigger that has something like:
User: Reporter
Check to perform: 'contains'
Value: '@emaildomain.com'
Anyone have an idea how to best set up an automation for this?
Here is what I can currently see and it will only give me a list of users already in our system.
Hi @[deleted] ,
You can use this "advanced compare condition" to achieve it.
Amazing thank you so much!
Hi all,
In this case, can I put at the same automation many domains?
I have the same problem, but I need to configure this automation for 100 domains to edit a field value.
Can you help me in this case?
Tks
