Use Rovo Agent not completing task when using Automation
Brad Lauzon
August 18, 2025
I have a Rovo Agent that creates a wiki page on each run. It is tested and runs perfectly on demand. I want to automate the agent to run daily using the Automation feature. I created the rule with the schedule and "Then: Use Rovo Agent" I included the same prompt that I use to manually run the Rovo Agent in the Automation required prompt field.
I verified the rule and got the green check for no errors. When I run the rule manually, I always get a green "success" in the status with about a 20-30s run time; however, it never creates the wiki page.
Suggestions?
Charlie Gavey
August 26, 2025
Hi @Brad Lauzon - did you get this working? As Mauricio mentioned, you just need to add the "Create page" action and use the agent response smart value.
If you have any other questions or feedback on using agents and automation, feel free to book a chat with the Automation product team here: https://calendly.com/cgavey/automation-feedback?month=2025-08
Mauricio Pelissari
August 23, 2025
I have the same issue—when I use the agent in an automation, it doesn't throw an error, but it also doesn't create the page in Confluence. I had to take the agent's output and use the 'create page' action instead, but it loses the formatting
Marc - Devoteam
August 19, 2025
Hi @Brad Lauzon
Whenever you ask for help with an Automation Rule it will help us to help you if you provide:
1. what type of project is this (e.g., company-managed, team-managed, etc.),
2. images that show your complete rule.
3. images showing the details of any relevant actions/conditions/branches.
4. images showing the Audit Log details for the rule execution.
5. Explain where the issue is.
These questions are not for not willing to help, but to have community members understand on how automation works.
