×I have a project in which I need to extract the details of Jira tickets to implement in a database and start comparing them,
I need to use the web scraping selenium python to extract the data, is it feasible?
If yes can you please provide a method so I can continue the work,
Kindest Regards!
What happened to simply export the tickets to a flattened file structure which you can use? To be exact use the advanced issue search of Jira to export the issues.
i think this will be possible, the most easy thing will be to know each issue key. But my question is why you don't use the API ? Is more flexible and simple that selenium for me.
