The issue created trigger does not work for issues created by Automation for Jira
Mykola
December 15, 2021
When I manually create a new issue the automation runs and I can see it in the audit log. But when Automation for Jira creates a new issue, as a result of another automation rule, the automation does not run and I do not see anything in the audit log. What can be a problem here?
You can see my automation rule below.
5 votes
Dirk Ronsmans
Hey @Niko ,
On your rule details you should see a checkbox "allow this rule to be executed from another rule"
Can you verify that this is enabled?
Mykola
December 15, 2021
Yes, it's there. I checked it and now everything works perfectly. Big thanks to you!
Parth Bindroo
September 8, 2022
Thanks for this :D
Rajesh.Kumar June 12, 2023
Thanks @Dirk Ronsmans , it helped me today.
