automation - prevent automation rules create a issue if already created one similar
Administracion JIRA
July 3, 2020 edited
i want to create a issue in a specific project (AYISA) when a specific user ("PEPE") add a comment on any project. This is a global rules and trigger with "add comment".
I want to have a clone of the original issue commented, not interest in the comment itself.
The problems is when user add another comment in the same issue, automation rules create a new ticket. That is what i call "duplicate issue" and i dont want this new ticket.
In other word, if a particular issue trigger automation rules (means clone was created in AYISA), do not trigger that rules for that issue anymore.
It is possible?
thanks in advance
Andreas Knecht
July 5, 2020
Hi Federico,
So I reckon the best way to solve this, is by linking the two issues and then adding a 'Related issues condition' to your rule to check if a linked issue already exists.
So a rule like this would work:
  • Trigger: Issue commented
  • JQL condition (like you have today)
  • Related issues condition that checks *no* linked issues exists (could also use JQL here)
  • Clone the issue to AYISA
  • Link the most recently created issue to the trigger issue
Hope that helps!
Andreas
Administracion JIRA
I think something like when automation rules is triggered for first time (means specific user add a comment) in the clone issue add a custom field populated with the {{issue.key}}. If triggered again from the same ticket, compare that field with the source issue.key and if the same don't create new issue, do nothing.
IMPORTANT: I cant touch source issue. (cant add a label or something)
