is there a way to create a test plan or test set with a product atlassian?
Bruno Bernadet July 22, 2021
hello
My enterprise use jira and Xray and it's going to be develop. We try to create by automation based on a query a test plan or a test set because we tested a lot of product. We use test with manual steps for a lot.
is there a way to create a test plan or test set with a product atlassian? Or another add on?
Rogério Paiva - Xray Xporter
July 28, 2021
Hi @Bruno Bernadet
In Xray, most of the information is based on Jira issues so that you can apply typical Jira issue operations to Xray Issues as well.
So, yes, in Xray, you have Test Plan and Test Set issue types, and you can query them using JQL.
Any additional questions, please get in touch with Xray Support (http://xraysupport.getxray.app); we would gladly assist you.
Thank you.
Rogério Paiva [Xray Support Team]
Bill Sheboy
July 22, 2021
Hi @Bruno Bernadet
I do not have Xray to try this, and I expect that if you can create a query to determine what tests to create, that you can create them using Automation for Jira (A4J).  The automation is built in for Jira Cloud, and is available for Server/Data Center as a free (Lite) or paid (Pro) version.
Please check the Xray vendor product's documentation to determine if those test entities are just issue types in Jira, or stored elsewhere and so require calling their REST API to create them.
Best regards,
