×Is there a way to display a custom JIRA field in Create JIRA Issue screen in Confluence.
By this what I mean is from the snapshot below I see only Project,Issue Type,Summary,Component,Version/s,Description fields.
I need to display another JIRA custom field, is it possible? If so how ?
Hi, as i see in this Confluence issue on Atlassian project since Confluence 3.5 you can create issues from the confluence. The problem is that how it says on one of the comments: ' there are some limitations around mandatory and custom fields which mean that some project configurations may prevent creation of issues from Confluence.'
Check here: https://jira.atlassian.com/browse/CONF-12882
Here it is the official documentation:
It looks like is not possible to add more fields to the screen.
What you can do is ask on support.atlassian.com for a new feature.
Cheers.
Hi, did you find the solution for this issue? Thanks.
There is something new with it??
I would like to know if i can set custome field in the screen view when try to create new Issue from Confluence??
I have the same issue, I have a custom field that I called Client for an issue. I see the field when I create an issue on JIRA but I dont see it when adding from Confluence.
