Automation: How to send a notification within Confluence?
Verena Gisler
Hi everyone
I am quite new to Confluence and only getting to know all the features. So now I am under checking out the Automation. I would like to create an, in my eyes, easy rule, namely that a specific user gets informed when the status of a page within a certain space has been changed from Draft to Review.
Now I only see the following possibilities for a notification:
These notifications are all outside of Confluence. So how can I trigger a notification to be sent within Confluence?
We have this little notification bell on the top right, so I would like to see the notifications there.
Is there a way to achieve this? Or do we really need to do the workaround by opening the notification in another app and return to Confluence?
Thanks a lot for your help!
Regards
Verena
Valerie Knapp
Hi @Verena Gisler , thanks for your post.
If you comment the person, using a smart value to mentions the user, this should generate a notification
Have you tested this? Do you think it would help you?
Please have a go and share your results and / or feedback.
Best wishes
Verena Gisler
@Valerie Knapp
Hi Valerie
Thanks a lot for your quick response.
I have tried your suggestion and added a comment with this explanation.
It works quite well and a comment is added! That is great! BUT I neither get a notification by email nor in the workbox (bell).... So do you know if there is a way to show all comments where I am mentioned?
The goal with this would be to send a notification that I need to review this page before it will be published to our customer help site. A workaround I now made is that in case the page status is changed, the page will receive a new label "to be reviewed" and then I can filter for all pages that have this label and review them.
Have a good day
Verena
