Having a project team with a clear side bar ,without Components, is the goal here.
So you can have a screen with out components but still the project has this on the side.
The rest of the side bar is controlled by the Features setting, does anyone know how to accomplish this?
EDIT: sorry if this wasn't clear my objectives are due to the organization that deals with various levels of technical knowledge, so I often try to simplify things. Many projects in this organization are not using components and never will and I would like them to not see it in the side bar.
Would be a great enhancement to manipulate them or at least hide them so you can remove ones you are not using any longer.
@Sean -
I agreed with what @Jack Brickey stated, one cannot remove "Components" listing from the side bar even if the project doesn't use it. Components is a default functionality of Jira/JSM application in both Cloud/Server envs.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Infrastructure Applications Team
Viasat Inc.
Since we can't remove the components on the sidebar, would you want to change the permission so people can not make edit to the components even if they see it? Would that help to achieve your goal even though it's not ideal?
agree...understanding more completely your objective may lead to an acceptable solution.
agree too. By default, only project Administrators role members can manage components in both Jira/JSM applications.
Best, Joseph
I don't think this would be possible on Cloud. You might be able to do it on Server\DC using ScriptRunner though.
Like Jira itself, ScriptRunner for Server is a very different application than ScriptRunner for Cloud.
SR for Server has a concept called "Script Fragments" that can, among other things, be used to manipulate the Jira UI, and I think could maybe hide things like the 'Components' menu option.
However the Cloud architecture doesn't give add-ons a way to get at this functionality; my guess is they were doing some pretty low-level hackery to make changes that are OK in a single-instance box but would never be safe\secure\scalable in a multi-tenant architecture.
Thank you,I often want to make some changes to the original UI of Jira Cloud like the title owner, and I'm worried about this!
Actually you can remove it, by using ?mode=global at the end of your url. I have everyone go to a landing page that has ?mode=global at the end (which is bookmarked of course) and then all the links from that page also use ?mode=global, best solution I could find but it does work
I'd want to know why you are trying to remove components in the first place? This is a OOTB functionality, and can be used for many different reasons.
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Become an effective Jira admin
Manage global settings and shared configurations called schemes to achieve goals more quickly.
Streamline Jira administration with effective governance
Improve how you administer and maintain Jira and minimize clutter for users and administrators.
Learning Path
Become an effective Jira software project admin
Set up software projects and configure tools and agile boards to meet your team's needs.
