Issue when connecting Jira with Power Automate
Kinka Family IT
Hi Everyone
I am having a issue when trying to connect Microsoft Power Automate to Jira, I want to try to create a flow to populate a Sharepoint list when a new issue is submitted to Jira however the Jira connector keeps erroring with:
X-Request-JiraInstance is not provided
I have established the connection using the API token but still receving this error
Any help is greatly apprecaited
Thank you
Primož Rajbar
January 8, 2025
I managed to solve this by first entering my Jira instance domain, e.g. https://example.atlassian.net/.
After that, the Project dropdown got populated successfully.
I got worried that this remained unfixed for so long. In the Jira Connector docs the field "Jira Instance is not mentioned as required, likewise in the UI. "Jira Instance" should IMO be the first field there and also a required field. That would save a lot of headaches.
David Gray
September 19, 2024
Atlassian and Microsoft need to fix this.
It's a premium connector in Power Automate, and therefore we're paying for it. Ignoring the issue is unacceptable.
The connector for when an issue is created works. It asks for an environment and a project.
The connector for when an issue is completed doesn't work, and only requests a project (not an environment, despite Microsoft's technical docs saying that is an input for the trigger).
Caitlin.Pedersen
Hi, I have a similar issue, does that mean this hasn't been solved yet? :(
Manohar Kurapati January 23, 2024
I am also facing the same issue.  I came to this thread after searching for a solution. it's a shame that Atlassian is not fixing this basic connection issue.
Steven Vits
any update? I try to configure a connection with a new API token.
no instances are listed but it seems you cab fill them in manually.
Steven Vits
 excuse me double saved
Jakob Gillinger
I have talked to Power Platform support and they have been aware of the error and are still working on a solution. Try it again in a week.
Kinka Family IT
thanks for letting me know
Prameela Janardanan
June 5, 2023
is the above issue resolved?  I am facing similar issue when I am trying to use the trigger when an issue is closed to update the status in Sharepoint list.
Kinka Family IT
No, I haven't been able to get this resolved yet
sairamakrishna nampalli
July 5, 2023
@Prameela Janardanan @Kinka Family IT
is this solved?.. Please let me know
Kinka Family IT
Hi
no not yet, i spoke to Atlassian support about it but their only solution was for me to pay them $2000 USD to get it setup
FREE
