×Hi,
Can someone please help configuring some smart values for some insight Custom fields.
I'm using Project Automation to automatically update the Summary of issues logged through the Service Desk portal.
I have one custom field of type 'Insight Object/s' called "On Behalf of" (custom field ID 26602) which references the "User" Object in Insight. This field has been scripted to default to the current user if left blank.
And I want to add the "Office Location" attribute from the selected User record to the Summary of the issue.
I've tried a few different things:
Facilities Request - {{customfield_26602.(Office Location.name)}}
Facilities Request - {{customfield_26602.(Office Location)}}
Facilities Request - {{customfield_26602.office.location}}
None of which have worked. Can anyone advise how I can pull an attribute of an insight object into a smart value to display in the summary? Any help would be appreciated. Thanks.
How about:
{{issue.customfield_26602.Office Location}}
or
{{issue.On Behalf of.Office Location}}
Cheers.
Hakan
Hi Hakan,
Thanks for the reply.
I just tried both of these and have had no luck unfortunately.
The automation says success, but that field is missing (it should be in-between the two hyphens:
Can you print some more additional information to the audit log to see the details?
{{issue.key}} -> This should show the issue key of the issue you are working on.
{{issue.customfield_26602}} -> This should show the object key of the "User" object in the Insight custom field.
{{issue.customfield_26602.Name}} -> This should show the Name attribute of the User object type (I am assuming you have the Name attribute).
Hakan
Hi Hakan,
I added all of those fields to the automation to test as follows:
{{issue.key}} - {{issue.customfield_26602}} - {{issue.customfield_26602.Name}}
I then tested this by populating the "On Behalf of" field to another user and I got this summary:
PPBSR-777 - Rui Cunha (PPBCMDB-270725) -
Even though the object does have a name attribute in insight (see attached)
