I'm using a custom insight object on Jira issues. There is an issue with project id/name expression. I'm trying to filter Insight objects using the project name or project Id in Insifgt custom field (https://support.atlassian.com/jira-service-management-cloud/docs/configure-the-insight-object-field/). I tried this:
Filter issue scope (IQL): objectType = "General catalog" AND Category = ${customfield_17287.label} AND Client IN (${pid.label})
and this:
Filter issue scope (IQL): objectType = "General catalog" AND Category = ${customfield_17287.label} AND Client IN (${pid.id})
but nothing works. Everything works fine if I'm using strings instead of ${pid.id} part.
The insight field "Client" is a select attribute with multiple values.
Insight custom field is available on the issue edit screen and I want to get the list of the objects for the current project only.
Can you help me, please?
Thank you,
BR, Petar
