Automation: delete specific comment using ID
Peng Zhou
July 11, 2022
Hello all,
Using automation, I'm trying to get the ID of a specific comment to delete it.
So what I want is:
  1. Resolving Issue A creates a comment in Issue B
  2. Using automation, I can get the ID of the specific comment in Issue B
  3. Using automation, I can delete the comment in Issue B
Where I am is:
    1. This comment includes the issue key and is a URL to the issue in Jira (see image) image.png
I am stuck here. I can't seem to get the comment ID. I am using the following smart value.
{{#comments}}{{#body.startsWith("text"){{id}}{{/}}{{/}}
This smart value does work. It works when the comments starts literally with text. However, I want to use a smart value instead of "text", but it doesn't work and I get an error message. So it would look like this.
{{#comments}}{{#body.startsWith({{triggerIssue.key}}){{id}}{{/}}{{/}}
 I have tried variations but I only get error messages in the log.
Nicolás Figueroa
Hi, I was trying to get the id created by an own automation because if the user fix the erros the comments should not be there anymore.
So to capture the commentId, I stored it in a automation Variable using:
{{#issue.comments}}{{#if(exists(body.match(".*(YOUR TEXT).*")))}}{{id}}{{/}}{{/}}
This will retrieve the id of the comment which has YOUR TEXT
Connor
July 11, 2022
Hi Peng Zhou, why are you adding a comment to Issue B when Issue A is closed, if you're just going to delete the comment anyways? Wouldn't it be simpler to just not create the comment in the first place?
