Get Asset Attribute using smart values
Junka July 21, 2025
Hi All
I am using JSM Data Centre
I dont have script-runner
I have a custom field for assets customfield_100
which contains an asset with text attributes
Key
Name
Serial
I can create an issue and retreive the Key using
{{issue.customfield_100.Key}}
This works fine
However I cannot get the Name, or Serial Number values
On a slight side note, I understand (probably incorrectly) that
you can do a lookupassets query, but I cannot get this to work
{{LookupAssets(Key={{issue.customfield_100.Key}}).Name}}
This looks logical to me but doesnt work, and Im not  sure if it would even help with the above
Thank you very much with the above
Junka
Marc - Devoteam
July 21, 2025
Hi @Junka
For name, you can use;
{{issue.customfield_100.Name}}
For Serial Number
{{issue.customfield_100.Serial}}
Pedro Olmo
Hello @Junka ,
When you have the object's ID using the custom field, you can use automations to perform a Lookup Objects and search for that specific object. Once you have the object in the automation, you can retrieve any attribute using {{lookupObjects.attribute}}.
Regards
