I would like to explore Atlassian AI Summarize and create timeline incident in slack option
This is not working currently as we are getting ‘You can't execute this command since there are no incidents linked to this channel.’
Can you help me to use Atlassian intelligence to link and summarize and create timelines of incidents from slack channel
This behavior usually occurs when no incident is currently associated with the Slack channel. Atlassian Intelligence relies on a proper connection between a Slack channel and a Jira Service Management incident to work. Here’s how to fix it and start using the features you want:
Step-by-Step: Enable Incident Summaries & Timelines in Slack
1. Ensure Atlassian Intelligence is Enabled
2. Link Your Slack Channel to a Jira Incident, Either:
/jsmops create timeline
in the incident’s Slack channel.
3. Grant Necessary Permissions in Slack
4. Use the Timeline Command After Linking
A modal will open to help you select key Slack messages and incident updates to include in the timeline. It then adds the timeline to both the Jira incident and the Slack channel.
Answered by Jer-nee Consulting, an Atlassian Gold Solutions Partner. We're here to support you in your success, feel free to reach out if you have nay other questions or issues.
