How can I schedule a Jira automation for every 3 hours using CRON expressions
Srujan Kumar
February 9, 2023
Please help us to schedule a Jira automation for every 3 hours using the CRON expressions.
Vamsi Kandala
February 9, 2023
Hi @Srujan Kumar
Welcome to the Atlassian community!
You can use this:
0 0 0/3 1/1 * ? MON-FRI
For running every 3 hours Monday through Friday
There are online tools like https://www.freeformatter.com/cron-expression-generator-quartz.html or http://www.cronmaker.com/ to help generate the CRON expression based on your requirements.
Hope this helps.
Vamsi
Joseph Chung Yin
@Srujan Kumar -
Welcome to the community.  Here is what you can do -
Create an automation rule using the "Scheduled" trigger setup.  You can click on the Advanced (CRON expression) tab to use CRON syntax if you want to.
Hope this helps.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Technology Applications Team
Viasat Inc.
