How do I create a Problem ticket with Corrective Task in OpsGenie or JSM?
Todd McNerney
August 2, 2022
I have always used the Service Now model of Incident and Problem ticket. How do we do the Problem Piece in JSM/ OpsGenie?
Eugenio Onofre
Hello @Todd McNerney
If I understood your scenario correctly, you would like to map Problems using Jira Service Management and Opsgenie.
In order to do so, you would need to have an ITSM project created into JSM and, once the project is created, you will have Incident and Problem issue types.
In order to establish the relationship between them, you would need to use the "Link" functionality, which gives you the ability to establish the correlation between incidents and problems.
The documentation below shows you how to link tickets in Jira:
https://support.atlassian.com/jira-software-cloud/docs/link-an-issue/
Eugenio
Eugenio Onofre
Hi @Todd McNerney
Please remember to accept this answer in case it helps you resolve your question as it may also help other community members in the future.
Eugenio
