×As in the title, I want to get all users of a specific group using smart value. What should I do?
There is no smart value for groups.
As discussed here, the Atlassian team member confirmed.
Why do you need this smart value, automation? Sending notification?
BR, Olga
The user name of the custom field cannot be specified as Assignee.
So I want to compare it with the user display name in the group.
Do you want to compare if a user from the "custom field" matches users in a specific group?
Or you want to copy the user from the "custom field" to assigne?
If you have user cf this filed must be specified as "user picker" type field
BR, Olga
I want to automatically send a mail to a specific user with a list of users from a certain group using an automation role for Jira cloud.
As I understand there is no smart value for groups.
Can I get such a list from [~accoundId:group count id] ?
Chana
