How to Add Bulk Versions in one project without using Script Runner?
jakeeryasmin June 13, 2023
Hi Team,
Please can you suggest Is there any other possible way of  Adding bulk the versions in one project without using the Script Runner
Deepak Jain
Hi @jakeeryasmin ,
Thanks for writing in Atlassian community.
You can use a simple trick with CSV importer to import multiple versions in your project. Create one test issue in your project and import all the versions to this issue:
IssueKey, IssueType, Summary, FixVersion, FixVersion, FixVersion
Test-1, bug, "Third issue", v1, v2, v3
 This way it will create all versions in your project.
Thanks !!
FREE
