Need help in Importing Assets From Manage Engine/Desktop Central/Endpoint Central.
Under the asset schema import section the following message is appearing:
"Your external app needs to be set up first before mapping the data. Connect your app to the import by adding a generated token."
I have added and authorized the Endpoint Central App and this appears under "your apps" but there is something missing still. There is limited documentation I could find on 'external app sources'
if anyone could help that would be great!
Did you end up getting this working?
@Gilly Joshi I am trying to get this to work right now too! Did you ever end up finding a solution? I'd love to hear what worked for you if you're able to share! :)
