Does anyone have an example of a JSON body that can be used to create a JSM issue and, within the same body, link an Insight object defined in a custom field? I cannot figure this out, I've tried multiple different ways, the issue is created successfully but the custom field is not populated.
I can do this using the following payload in my JSON
"customfield_XXXXX": [
"workspaceId": "WORKSPACE_ID",
"id": "WORKSPACE_ID:OBJECT_ID(NUMBER)",
"objectId": "OBJECT_ID"
How to get WorkSpaceID:
Access the URL: https://URL/rest/servicedeskapi/insight/workspace;
Collect the ID present in “WorkspaceId”.
How to get the ObjectID:
Access the insight and go to the desired object;
The “Object_ID” number is the numbering information that follows the object's key in Insight.
Excellent! That worked, I will say it seems like overkill but I'm not complaining. Thanks!
