Link issue from Project 1 to Project 23
Noemi Csaszar November 4, 2024
Is it possible to manually link an issue with a DONE status from Project 1 to Project 2? This linking should be applied manually and only for specific issues.
Thank you!
Kris Dewachter
Hi @Noemi Csaszar ,
Welcome to the Atlassian Community.
Yes, you can use the "Link" functionality to link an issue from project 1, to an issue in project 2.
https://support.atlassian.com/jira-software-cloud/docs/link-issues/
Best regards,
Kris
Hi Kris and thank you so much!
So, I can link an issue in Project 1 to an issue in Project 2, but I can’t link an issue directly to the entire project itself. As I found in the link you shared, JIRA's linking functionality only supports issue-to-issue connections, regardless of the projects they belong to.
Have a good evening,
Noemi
Kris Dewachter
Hi @Noemi Csaszar ,
Correct. Everything in Jira is "issue" based. So you can link issues to other issues (in the same or in another project). But you can not link an issue to a project.
Why would you want to link to a project? Do you have a use case ?
Best regards,
Kris
Noemi Csaszar November 5, 2024
Hello @Kris,
Yes, I do have a use case. I would like to link an issue to a project because, in some cases, projects are created as a result of specific issues that have been completed. We need a way to track the issues that have led to the creation of new projects.
Noemi
Kris Dewachter
Hi @Noemi Csaszar ,
You could also add a "web link" to your issue. You could link to a project url, issue list or dashboard of the project. You need to copy/past the url in the web link.
Best regards,
Kris
