Move linked issues section when viewing issues
Leon
When viewing a large issue, the agent needs to scroll down until they realise it might be linked to a number of other issues.
How do i move the linked issues section to the top of the issue?
I have tried to edit a few screens but it does not seem to work.
Daniel Ebers
August 2, 2021
Hi @Leon
currently there is no option to move this area to the top.
I found a Suggestion:
However, this does not talk specifically about the linked issues section - it seems to got migrated over from an older issue at a time when 'New Issue View' was not even invented and due to its age probably there will not be a high likeliness that it every gets touched.
On the other hand, you could comment the Suggestion or open a new one if you wish.
To be honest, from a highly personal view I believe there will be no option to address your requirement - while it is very understandable what you described.
Daniel
tellthebell
July 29, 2021
I am also having the same issue. Thanks for sharing these information.
FREE
