Problem with Jira automation
Timppa October 10, 2017
We have a little problem with Jira automation rule.
We use automation rule which edit component and alert user when SLA time remaining: Trigger is Breached.
Sometimes that rule stop working and only way to fix it is to reboot our Jira server. This problem appears once a week or sometimes it works just fine several months. All the other rules works just fine.
Any tips why that rule stop working or how we can track main cause?
Gonchik Tsymzhitov
Hi!
1. Just first question, your Automation version is latest?
2. Could you set debug log for Automation plugin?
3. Just check ERRors in Debug logs, it will be nice if you provide.
https://confluence.atlassian.com/adminjiraserver071/logging-and-profiling-802592962.html
Gonchik Tsymzhitov
Timppa October 11, 2017
1. Automation version is 2.3.4
2. We set debug on and follow the situation. Let's hope that the logs will give as some answers.
Like Miftahur Rizkie likes this
Gonchik Tsymzhitov
Hi!
Looks like we speak about different plugins:
I mean about this one.
https://marketplace.atlassian.com/plugins/com.atlassian.plugin.automation.jira-automation-plugin/versions
Could you provide a product key?
I have checked on out the box plugin (com.atlassian.servicedesk.plugins.automation.servicedesk-automation-plugin) with version 2.4.4 for JSD  3.6.1.
Unfortunately, I can not reproduce it.
Could you test on your env with this version?
Gonchik Tsymzhitov
Timppa October 12, 2017
Thanks for your answer.
Yes the automation what I mean is the one which comes with JSD not a add-on from Atlassian Marketplace.
Our JSD is 3.3.0.
What do you think if we upgrade our SD 3.3.0 --> 3.8.1 it might also solve this problem?
