Project automation: create rule for comments from portal
systemlos March 31, 2023
I am trying to create a rule, which transitions my issue when a comment is created. This basically works fine.
But when I am trying to add a condition, I am failing:
I want my issue only to transition, if the comment is created in the portal and not in the Jira backend.
I know that there are certain properties and that it is possible to set them with the "advanced compare condition" but I am not able to find out the right parameters.
So I have two questions:
1.) how to write my condition, so that my rule is only triggered my comments created in the service desk portal?
2.) does there exist a list with all field properties and an explanation for what they are used?
thanks for your highly apreacciated help!
(I am project administrator, but not a Jira administrator with global permissions)
Jan-Hendrik Spieth
March 31, 2023
Welcome, @systemlos :-)
Have you also tried setting a "User condition"? I think this might work, using some group, role, organization or so, as condition then.
About "all field properties" - the documentation for smart values might be a place to start?
Hope this helps...
systemlos April 3, 2023
thanks for reaching out to me.
everybody is allowed to raise requests. The user condition would not be perfect, because if a user is an service desk customer and an agent at the same time, a comment in Jira would be interpreted like a comment from portal. Best would be a certain property, where I can declare,  that the comment had to be raised by portal.
thank you for the link :)
these IF conditions will do as a workarround for now:
