Hi, I have configured an Automation Rule to copy the comment from the issue to the related issue in another project. For the first comment it works but for the other I see the message in the audit log:
No new comment was added since this issue has been commented on before
Could someone help to understand it? And also, there is some place where I can consult this audit log messages?
Thank you
Maycon
Hey @Maycon Belfort ,
could you check your action component that adds the comment.
There you should be a checkbox to "not add the same comment multiple times" (it is enabled by default).
This usually blocks me when I try to set this up.
Thanks @Dirk Ronsmans after uncheck this option my comment was add to the related issue.
When I put a new line in the comment it is copied with "\n". Is it right?
Thanks.
Hi @G subramanyam I have seen that the first link solved my problem with the comment's new line.
