Hi
I am trying to get an automation that does the following
Run when the following
Everything is working until the final step where it is not setting the request type, but instead removing it completely. Cannot figure out why this would be the case or how to resolve. Any help appreciated
Hi @Nick Turner - I'd need to see the rule, but it is likely that you need to perform a branch into the newly created issue. Something like this:
If this is what you have already, please share screenshots of your rule and the audit log.
Thank you Mark
I wasn't using the Branch for recently created issues as the next step. That worked a treat. Thanks very much
We'll need more details on your setup, @Nick Turner - but based on what you describe, the most likely reason why the last step fails is that request types are linked to issue types in Jira Service Management. If you are trying to set a request type that is not available for the issue type you have just created, then this will fail.
If that is not the issue, share any error messages you may see in your automation rule's audit log and the way you have now configured the part where you are trying to set the request type (ideally even screenshots of your entire automation rule)
Hope this helps!
Thanks Walter, This has been fixed by creating the correct branch action. Thanks for your reply
