I am not too sure if this is possible but when an issue is created in Project A, and will transition to a specific status in the project, is it possible to create an automation to clone that issue to a different project - however, it would need to clone and create multiple new tickets based on the choices picked in a multi-choice picker field?
Example - ticket created in Project A and the choices in the filed is "System 1" and "System 3" (as per attached image).
When this ticket transitions to "In Progress", an automation should kick off to create 2 new tickets in a different project, one for "System 1" and one for "System 3".
Would something like that be possible?
Thanks.
Yes, this is definitely possible, the automation should look like this:
Trigger: Issue Transitioned (to your desired status)
Condition: Check fields value (and make sure it's not empty)
Branch 1 - For Current Issue
Condition: Check if field contains System 1
Action: Clone Issue to Project System 1
Branch 2 - For Current Issue
Condition: Check if field contains System 2
Action: Clone Issue to Project System 2
You can do as many branches you need, if you need more help with that let me know:)
Thank you @Jakub Koc - I had attempted this but think I just need to check on adding the condition to make sure the field is not empty and I thought about branches as well! Much appreciated.
Hello @Drishti Maharaj
If you're seeking for an easy way to clone an issue into multiple ones in another project, I suggest trying our app Elements Copy & Sync that allows you to clone and sync a full hierarchy of issues with all their content (summary, description, custom fields, comments, attachments, etc).
You can check our guide here.
The app is compatible with both Automation and Post-functions.
The app is for free during 30 days (and it stays free under 10 users).
