Customfield with unique values for each Project
Pär Jansson January 16, 2024
Hi, I'm wondering if it's possible to  create a Custom field for all projects to use but each project has there own unique dropdownlist with  values just for that project.
Sreenivasaraju P
January 16, 2024
HI @Pär Jansson ,
Yes. You can do it.
You can have separate context for each project (some projects). Each context can have different options.
https://support.atlassian.com/jira-cloud-administration/docs/add-a-context-to-a-custom-field/
Thanks for the reply!!
Marc - Devoteam
January 16, 2024
Hi @Pär Jansson
Yes you can.
Create a custom field context for each project in your custom field.
See the KB article here
