Does Jira automation provide a way to export a csv file when closing an issue?
Chisato Saito
I find a way to export JSON file(to use Webhook )but I need a csv file by automation.Has anyone done this?
Esteban Diaz
October 9, 2023
Hi @Chisato Saito ,
Not possible with Jira out of the box but....
You can try this add-on: Xporter , it is great, easy to use and will fulfill your requirement.
Esteban Diaz
https://www.linkedin.com/in/estebandiaz/
Chisato Saito
Thank you so much!!!
Like Esteban Diaz likes this
FREE
